WAB refused to connect
2627
5
05-24-2016 02:11 PM
RamS1
I am using local WAB on my machine. I am getting "machine name refused to connect". I have verified I am using correct App ID in Server\Config.json file. It starts working when I run startup.bat file again. It used to work until I keep my browser now it is coming after few minutes.
Do I require to add my organization proxy under server/proxy.js?
your help is appreciated!
RebeccaStrauch__GISP
If you haven't done so already, you may want to read thru Tips and Observations for getting Web AppBuilder - Developer Edition Installed making sure you follow all the steps on the AGOL side.  There are links to other resources and install guides on that page too.
I know for my machine, I've always need to run thru the startup.bat 2x.  First time it never does anything, but I believe it does start up the node.js.  I close the window and run it again and it fires up.  jsut an fyi.
RamS1
Thanks Rebecca for your response.
RobertScheitlin__GISP
Ramy,
Are you saying that you have added the appId to specific apps config.json (i.e. [intsall dir]\server\apps\[app#]\config.json)?
Or are you talking about the [intsall dir]\server\signininfo.json?
Have you tried to delete the [intsall dir]\server\signininfo.json?
I have never seen the "machine name refused to connect" error can you share a screenshot?
RamS1
Thanks Rob for your response. .Please see screenshot below. I am using Google Chrome Version 50.0.2661.102m. I am getting same message on IE11, Firefox browsers. I am using Windows 7 64 bit OS. I have deleted server\signinfo.json file and this error is persistent.
Ramy,
When you run the startup.bat it opens a command prompt window.
  1. You are not closing that window are you?
  2. What happen when you use http://localhost:3344/webappbuilder
