Getting invalid workspace error when publishing 'create version' tool as a geoprocessing service?
2068
05-26-2016 11:18 PM
AravalaSpandana
There is a customized 'Create Version'  tool written in Python. The tool was successfully being published as a geoprocessing tool till yesterday. However, when I now try to publish, the application hangs(click on Analyze/Publish and it hangs). The application needs to be closed.
When the server logs are checked(Level-Severe), it shows an error 'invalid workspace.Create Version Failed'.
How can I fix this issue?
Does 'Clear workspace cache' tool might help?
Request you to reply elaborately and put it in simple words explaining the cause and solution/workarounds as I am new to this.
Thanks in advanced!
