filegdb api - "UPPER" in sql query not working for Cyrrilic symbols
3749
5
06-05-2016 03:08 AM
OlegMaslenko
     Hi everybody. Do not scold for my English.
I'm using filegdb api v1.4. and have such problem with sql query.
SQL query for example: "SELECT * FROM City WHERE UPPER(TITLE_ENG) LIKE '%KIEV%' " - this is work
SQL query for example: "SELECT * FROM City WHERE UPPER(TITLE_RU) LIKE '%КИЕВ%' " - this isn't work.
     I noticed:
1) that function "UPPER" and "LOWER" won't work with the text contains Cyrrilic symbols. I tried to use "collate" but it didn't work.
2) that SQL query works in ArcMap
     Are anybody knows how to decide this problem with Cyrillic symbols!
DanPatterson_Retired
Interesting problem... a lot of the web links suggest converting to Unicode first prior to using upper or lower, however, I don't know about sql, but see this python example
OlegMaslenko
and where it is (python example)?
search using    python upper unicode  for example, yields many threads and links eg.
http://stackoverflow.com/questions/727507/how-can-i-convert-unicode-to-uppercase-to-print-it
OlegMaslenko
I think this method should not help! The word which must be founded I can do anything, but ho do like that
"SEARCH * FROM CITY WHERE UPPER(Encoding.UNICODE(TITLE)) = UPPER("SEARCHED_TEXT")"
well, I am not worried about the query now, since that is the end goal, and not the root of the problem.
I will leave this for others to ponder so they can answer your question directly
Pay attention to the equality checks and the type tests
>>> a = "КИЕВ"
>>> b = a.decode('utf-8')
>>> type(a)
<type 'str'>
>>> type(b)
<type 'unicode'>
>>> print(a)
КИЕВ
>>> print(b)
КИЕВ
>>> a == b # ?????
True
>>> c = "KIEV"
>>> type(c)
<type 'str'>
>>> a == c # ?????
False
>>> b == c # ??????
False
good luck
