Filling voids in DEM
6048
5
06-16-2016 02:35 PM
andylohmann
I recently downloaded a DEM and it has several voids in it. There is not a pixel where there should be. Is there a way I can fill these with reasonable data using arc maps 10.3?
DarrenWiens2
MVP Honored Contributor
See this help page that shows how to use Nibble to fill voids.
JayantaPoddar
MVP Esteemed Contributor
I hope this method will also work:
First, use Focal Statistics—Help | ArcGIS for Desktop using the above DEM to create an interpolated raster. This raster will also have the NoData values filled.
Next, use Raster Calculator—Help | ArcGIS for Desktop with the following expression
Con(IsNull("DEMRASTER"),"FOCALRASTER", "DEMRASTER")
The above expression will replace all the NoData values of DEM with the pixel values of the Focal-Statistics Output Raster.
Think Location
DanPatterson_Retired
for pixel sized holes normally (depends on window used)... for larger holes, the regiongroup, nibble combination is the way to go
XanderBakker
Esri Esteemed Contributor
For small areas with NoData I would go for the solution provided by Jayanta Poddar  (but using the two steps in a single raster calculator expression). For larger areas in the past I have used a procedure to:
  • detect the NoData Areas
  • expand the NoData Areas
  • use the expanded raster to get the border with values of the DEM
  • convert that raster into points
  • create a TIN
  • convert to raster and replace the NoData values with the TIN 2 raster result
However, these are a lot of steps and what is most important, if you have a large area of NoData values, you probably don't know what happens there and any method will assume things that may not be true.
Robert_LeClair
Esri Notable Contributor
The Fill (Spatial Analyst) GP tool may be worth a look as well.
