Can you query related tables in arcgis online applications
2798
06-21-2016 03:51 PM
AngelaVanderPas2
New Contributor III
I need to run "reports" from the data in related tables.
We are using related tables to collect data / maintenance in the field.
We need to query the types of maintenance based on selected dates.
I was hoping someone else is already doing this and has a good workflow.
AngelaVanderPas2
New Contributor III
The short answer is yes.  You can query a related table and return information based on the data in the table.  Now I am trying to develop a workflow that also brings the feature data that is related to the table data, so we can do calculations based on feature attributes.
Looking for some out of the box webapp widget options.  I am trying to stretch the online capabilities as far as I can with out having to delve into programming.
MajidHojati
Could you get any results? I have the same issue with querying related tables in such a way that output includes both data together. it seems Arcgis online does not let us do that?
BarryG
Hi Angela.  Can you give details of how you got the related table to AGOL, please?  I cannot get it to recognize the related table.
Thanks.
Yu1_
Create relationship classes in ArcGIS pro/ ArcMap. Than publish layer to online.
