Create(overwrite) style for Launchpad Theme
2499
06-22-2016 01:42 PM
RamyShah
I am unable to implement a new color using Launchpad Theme.  I can create a new style in Launch Pad Theme. I don’t see changes on theme. I am following this link
https://developers.arcgis.com/web-appbuilder/sample-code/create-a-style-for-a-theme.htm#ESRI_SECTION...
I have done changes in MyStyle àStyle.css and MyStyle à css à jimu-theme.css. I have restarted WAB Server but it doesn't change Header/Panel Widget colors. I have already checked following posts which didn't help.
https://community.esri.com/thread/171739#comment-585181
https://community.esri.com/message/586643#comment-586643
How to view changes done in style css files in custom themes
What I am missing? Thanks for your help in advance
RamyShah
How I can verify it is not due to Node.JS. I am using Node version 4.4.4.
Any help is appreciated!
by Anonymous User
Not applicable
Maybe try to create a new app and reselect that style?
MichaelAugust
Occasional Contributor III
I cannot get this to work either in WAB 2.2.
All I want to do is have a style swatch available for people to select and get certain colors, but the swatch shows up with the hex number on it, basically functioning as the custom swatch instead of a new color.  Can you double check that documentation and explain to us how to add a new style to a theme at 2.2 without using the "custom" one? So that a new selectable style appears under the foldable theme.
I am trying to modify the foldable theme and would like to be able to change the jimu-panel-title background to a different color other than the one displayed on the "custom" swatch, but it keeps getting overwritten somewhere, I can see my color when I inspect the element in web browser but it has a black line thru it like it's being overwritten?
