Select attributes that ends in numbers
5919
9
06-24-2016 02:25 PM
CCWeedcontrol
Occasional Contributor III
I have a feature class and in that feature class i have a field "SiteAddress" and most attributes t looks good but there are some attributes that have numbers after the address and they are not suite, unit or apartment numbers. I am trying to figure out how to query to select them.
Example of one is 24832 Trunnel Ct 8693, is there a way to select features with numbers after alphabet characters and delete the 8693 from ones that have the numbers after the alphabet characters.
any help would be great.
Thanks.
DanPatterson_Retired
write yourself a little function using this idea
>>> a = "24832 Trunnel Ct 8693"
>>> b = a.split(" ")
>>> c = b[-1]
>>> c.isnumeric()
True
so basically if the last entry in the parsed list is numeric written in scrunched form
if a.split(" ")[-1].isnumeric(): d = " ".join(a.split(" ")[:-1])
>>> d
'24832 Trunnel Ct'
of course you should have an else section which just returns the original string
DarrenWiens2
MVP Honored Contributor
Possibly a prettier way, but this should do it (luckily there are only 10 possibilities):
"SiteAddress" LIKE '%1' OR "SiteAddress" LIKE '%2' OR "SiteAddress" LIKE '%3' OR "SiteAddress" LIKE '%4' OR "SiteAddress" LIKE '%5' OR "SiteAddress" LIKE '%6' OR "SiteAddress" LIKE '%7' OR "SiteAddress" LIKE '%8' OR "SiteAddress" LIKE '%9' OR "SiteAddress" LIKE '%0'
>>> b = a.split(" ")
>>> c = b[-1]
>>> c.isnumeric()
True
>>> d
'24832 Trunnel Ct'
JoshuaBixby
MVP Esteemed Contributor
If you are going to be searching within and manipulating strings on a regular basis, I strongly encourage you to check out Pythons Regular expression operations.  Regular expressions are a very powerful pattern matching tool/language and one that goes well beyond Python.
Using your example, I believe the following regular expression will work for you:
>>> import re
>>> re.sub(r"(.*)\s\d+$", r"\1", a.strip())
'24832 Trunnel Ct'
CCWeedcontrol
Dan and Joshua i am not sure how to apply your suggestions.
I tried the following in field calculator but no go.
import re
def strip_num(a):
    '24832 Trunnel Ct'
strip_num(!SiteAddress!)
def x(a):
        a = " ".join(a.split(" ")[:-1])
    return a
then
x(!SiteAddress!)
now assume that the first value (which I will call 'a') is
>>> x(a)
'24832 Trunnel Ct'
CCWeedcontrol
I forgot to mention that is field is a text field, so it's throw a 000539 error.
Thanks.
That is a unicode thing
Now make a script... don't do this manually... make it into a script run it and does it work?  If it does then there is other stuff in your field other than the simple example that you reported
def x(a):
    return a
print(x(a))
CCWeedcontrol
Now sure how.
really? you surely don't retype everything when coding do you?
