In ArcGIS 10.4 Desktop I have a layer (point shapes) with *.jpg images attached to each georeferenced point. When I convert Map to KML the images do not come in with the KMZ file in Google Earth. How can I fix this? F. Ingram
2678
5
06-27-2016 04:14 PM
FrankIngram
I have ArcGIS 10.4.1 Desktop with a layer, Point Shapes, that have *.jpg images attached. When I convert "Map to KML" and open the KMZ file in Google Earth, the images do not come in with the layers. How can I fix this ?
Frank....
DanPatterson_Retired
You need to make sure your data are in the correct coordinate system (WGS84) Map To KML—Help | ArcGIS for Desktop
FrankIngram
Dan,
All the layers are in the correct coordinate system. The jpg images that are hyperlinked to the point layer in ArcGIS are not
Coming in to google with their associated layers. All else comes into Google, including each layers associated Table….but not the images.
Frank
In the link I posted, did you see the sub-links to ensure that everything was set up properly?
Setting HTML pop-up properties for feature layers—Help | ArcGIS for Desktop
Creating KML in ArcGIS for Desktop—Help | ArcGIS for Desktop
I would be guessing as to why the images don't show if they are popups
FrankIngram
Dan,
WELL……for the 5000th time yet another of my acquaintances have reminded me to slow down and think….thank you Dan
for # 5001….. HTML is just a tad picky about the symbols “/” &”\”.(Imagine that)
I owe you…..
Frank
p.s. and my thanks to the GeoNet community…..
FrankIngram
Jayanta,
coming in to Google with their associated layers. All else comes into Google great, including each layers associated Table….but
not the images.
Frank
