problem with Create fishnet tool
3387
06-28-2016 01:43 PM
Md_YousufReja
Having issues with create fishnet tool. I have made a index panel grid of 100 panels. Each panel has X and Y origin coordinates and scaled cell size. I have to make 2,880,000 cells from each panels. I ran the Create Fishnet tool to do that. However, every time the outcome didn't coincide with the original position because the tool itself rounded of the decimals. is there any suggestion to solve the issue?
DanPatterson_Retired
If you aren't working with a defined coordinate system, then you will have geometry issues.  Also, are you working in a projected or unprojected data frame?
Md_YousufReja
I am working with defined coordinate system and projected data frame.
And they are both the same? and what is it might help?
What values are you entering that you feel the decimals are being truncated or rounding? and dont' assess the rounding by what they appear in the table unless you have set the field to display more than the default number of decimals.
You might want to include a summary of your fishnet setting to provide information for more commeentary
