Basic Model Won't Overwrite Existing Data
8083
15
06-27-2016 08:20 PM
BenVan_Kesteren1
Occasional Contributor III
I have a model I created in Model Builder that simply runs several instances of the "Feature Class to Shapefile" tool.
If I run this tool over and over again, it keeps creating new files in the output directory, incrementing the filename by a single digit each time.
For example, if I run the tool three times I will end up with:
  1. Water_mains.shp
  2. Water_mains_1.shp
  3. Water_mains_2.shp
Is there a way I can tell the model builder to overwrite these files instead of creating a unique file name?
I reference these files in several maps, and I thought I was updating the source data for these maps, but each time I run it it creates a new filename so the data source needs to be updated accordingly (not ideal).
Do you know how to force the model to overwrite existing data?
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
In ArcMap, click Geoprocessing > Geoprocessing Environments.
Check the first option "Allow Geoprocessing tools to overwrite existing datasets".
Think Location
JayantaPoddar
Think Location
curtvprice
You can also set Overwrite outputs as in the properties/environment tag of the model (so the user doesn't have to do it in ArcMap for everything).
JoeBryant2
Curtis, could you be more specific? I don't see this option anywhere when I right-click my model > Model Properties > Environments > ?
FYI: 10.4.1
curtvprice
You are right, Joe, overwrite outputs can only be set at the application level (ArcMap > Geoprocessing > Options) or in Python scripting. Sorry.
JamalNUMAN
Legendary Contributor
This appear not work in Pro 2.5.
Jamal Numan
curtvprice
Jamal, I don't see any thing in your screen shot that is "not working".  Maybe you could describe your problem better?
It is true that sometimes one tool or another does not handle overwrite well, but for me overwrite output has been working a little more consistently than it does in ArcMap, mostly because Pro is a single application (as opposed to futzing with file locks caused by using ArcMap and ArcCatalog at the same time).
Though a common problem in Pro is that since it is multi threaded, you can have a feature class or field list open for editing when you try to run a tool and run into a file lock error. The fix is to go to the edit menu and save or reject your changes, this will remove the file lock so you can overwrite your output.
JamalNUMAN
Thanks Curtis.
The model shown in the screenshot below, is assumed to deliver “5” outputs. Currently, each time any parameter is modified in any of the tools that participate in the model leads to creating new output for that tool instead of replacing the previous output.
In the second screenshot, the number of outputs are more than “5”. I assume that the number of outputs for this model should be kept “5” if the outputs are overwritten.
Am I correct?
Jamal Numan
BenVan_Kesteren1
Hey Jayanta,
thanks for the comment, it seems I already have this option ticked on....
These are the current settings I have in ArcMap:
These are the current settings I have in ArcCatalog (this is where I open the Model Builder model from):
BenVan_Kesteren1
Here is a copy of the model I am using, is there a setting stored inside this?
https://dl.dropboxusercontent.com/u/32195871/Work%20Only/GeonetExport.zip
