ArcMap 10.2.2 crashes while checking out Data for ArcPad
1552
06-28-2016 07:25 AM
AndreasLülsdorf
Hey there,
I have a problem with the Data Check Out function of ArcMap 10.2.2. On my new Tablet-PC with Win7pro ArcMap crashes without error report when I try to check out more then 4 layers.
Is this a known issue?
Tags (3)
JuanLuera
Occasional Contributor III
Hola Andreas,
I wanted to see if your data is coming from a fgdb, mdb, sde or a shapefile? I would then want to know how many layers are you checking out and the "Action" option you are using to check them out of ArcMap. I would then ask if you have had success in checking out one layer at a time, from within ArcMap? These should identify the layer that may be causing the issue being seen, were ArcMap is crashing. Look forward to your responses on this issue with ArcMap and ArcPad. Gracias, Andreas!
How To: Check Out/In data from ArcMap to ArcPad for editing
http://support.esri.com/technical-article/000009343
Get Data for ArcPad
http://resources.arcgis.com/en/help/arcpad/10.2/app/index.html#//00s100000068000000
Juan
