I cannot create a new site -- ArcGIS Server 10.2.2
2638
06-28-2016 04:55 PM
DonaldBrown
I get the error: 0x80040154 - Could not create object 'ConfigurationFactory'. I am trying to install ArcGIS Server version 10.2.2 on CentOS release 6.8 (Final). I think I'm missing some packages. Is there a list of required packages for this operating system?
Thanks!
DonaldBrown
FYI - the corresponding message in the log:
<Msg time="2016-06-29T10:55:42,457" type="SEVERE" code="6533" source="Admin" process="30391" thread="12" methodName="" machine="IGSCSAHCPAGS5.AHC.CR.USGS.GOV" user="" elapsed="">Failed to create the site. com.esri.arcgis.discovery.servicelib.AGSException: java.lang.Exception: AutomationException: 0x80040154 - Could not create object 'ConfigurationFactory'.</Msg>
GriffinMorgan1
Server 10.2 is not supported on CentOS Linux. If you think you are missing packages, your best bet would be to look at the required Red Hat 6 packages listed in the System Requirements. http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#/ArcGIS_for_Server/015100000...
PGF50
Hi Donald
Did you manage to resolve this issue?
