Is there any way to use a "OR" function using field calculator?
1999
07-04-2016 07:45 AM
MichalDudek
Dear all,
I have a polygon layer that is a merged layer made from two different layers. Using merge tool I have an attribute table of a new layer that has two different fields (columns) for the same attribute. I would like to combine those two fields into one using the field calculator. The advantage is that for each polygon where there is a blank space in one field there is text describing the name of the polygon in the other.
Field1 - Field 2
....-abcd
....-efgh
ijkl-....
I was trying to use the equations: [new value] = [field1] + [field 2] and [new value] = [field1] & [field 2] but there is a space in the front of the value of field 2 in the output field (column).
Do you know how to solve it, how to deal with the blank space in the front?
I'd be grateful for any infomation.
Kind regards
JayantaPoddar
MVP Esteemed Contributor
Try ltrim() and rtrim() functions in Field Calculator.
Think Location
JayantaPoddar
If one of the fields is always blank, you can also try the following steps:
Consider A and B as your input fields, and C as your output field.
1. Select by Attributes for Field A,
IS NOT NULL
Once selected, replace the values of C with A using Field Calculator.
2. Repeat the Step for Field B as well.
Think Location
