showMagnifierOnTapAndHold not working in AGSMapView
1980
07-11-2016 12:15 AM
ShyamAgarwal1
down votefavorite
I am using a AGSMapView from the ArcGIS Runtime SDK. I want to show the magnifier when the user performs a tap and hold gesture on the map.
As per the documentation, I have set the following:
showMagnifierOnTapAndHold = true
Unfortunately, the magnifier is still not visible. Can anyone help me out here?
RyanOlson1
did you add the ArcGIS.bundle file to your project? If not, the magnifier probably won't show as it needs the image which is in the bundle.
RyanOlson1
