Can't seem to install WaterUtilityNetworkTools add-in
1884
8
07-13-2016 11:07 AM
JoshWhite
Regular Contributor III
Why can't I install the Water Utility Network Tools add-in?  Every time I do this I get an error that says "No GUI components found in this Add-in.  Add-in version does not match.  I am using 10.4.1 and this appears to be the most recent version of the add-in.
Josh White, AICP
Principal Planner
City of Arkansas City
AllisonMuise1
Occasional Contributor III
Josh White‌ did you figure this out? Could be that you have old version of other local government add-ins still installed, or could be that you didn't get the latest version of the add-in for some reason. The latest is available with the download from this page: Water Utility Network Editing and Analysis | ArcGIS for Water
JoshWhite
Allison,
I just tried this with your link and got the same results.  I did a search for waterutility and I deleted everything that looked like an add-in except for the new one I just downloaded and that didn't help either.  It came from a file called UtilityNetworkEditingandAndAnalysisA4W.zip
Josh White, AICP
Principal Planner
AllisonMuise1
Josh White‌ This add-in shares files with other ArcGIS for Local Government add-ins including Attribute Assistant, the addressing tools, and possibly a few others. There may be a conflict if an old version of one of those is on the machine.
The correct procedure for removing add-ins is here: Remove add-ins - Water Utility Network Editing and Analysis | ArcGIS for Water
JoshWhite
Nope didn't work, and now, my attribute assistant is gone and I can't add it back either.  I should add that I have never had to remove an old add-in before and have always been able to just upgrade as needed to the newest version without any hiccups.  Now I am unable to add any add-ins at all at 10.4.1.
Josh White, AICP
Principal Planner
AllisonMuise1
Hmmm...Something funny is definitely going on. What you are trying should work. I suggest contacting Support. They will be able to troubleshoot with you easier than I can through GeoNet.
-A
MaureenKamau
New Contributor III
Hi Josh,
Have you tried the solution recommended in the below tech support article;
Error: No GUI components found in this Add-In. Add-In version does not match
JoshWhite
Maureen,
That is a little more involved than what I want to do.  I don't have Visual Studio either.  I have opened a tech support ticket on it and they are working to help me.  Sounds like I may have to reinstall ArcGIS for Desktop, not my idea of a good time.
Josh White, AICP
Principal Planner
JoshWhite
As a follow up for those that may be following this thread:
Esri Support used the basic concepts found at Essential Python add-in concepts—Help | ArcGIS for Desktop
They sent me the add-in in its raw form (an Esri AddIn File) and installed it on the back end (by placing it in the well-known folder location C:\Users\<username>\Documents\ArcGIS\AddIns.  I've asked if the Add-in Manager has had any bugs reported because that appears to be the case with this.  There could possibly be a registry error that has prevented it from working as well, that would have been the next step prior to doing the reinstall mentioned above.
Josh White, AICP
Principal Planner
