Error 001272: Analyzer errors were encountered (codes = 4, 4, 4).
4692
07-18-2016 11:59 AM
ChristopherSchreiber
Occasional Contributor II
I am trying to over right a hosted feature layer on ArcGIS Online. I have the same layers (with 1 field type change) ready to be published from ArcMap 10.4.1.
I run the analyze tool and take care of any errors. Then, I select publish. When I do I get the following error:
I cannot find what the codes mean in the error message.
Has anyone else come across this message?
Chris
Robert_LeClair
Esri Notable Contributor
It's possible that the mxd is corrupt.  What you could do is create a new map document, add all your data, and then create/overwrite the service from the new *.mxd.  What is the result?
Robert_LeClair
Robert,
Thanks for replying!
I forgot to post it on GeoNet, but that was the solution that I was able to make work. I am running Desktop 10.4.1 and I did not change anything else with the new .mxd in ArcMap.
Thank you!
Chris
