How can I export the result from android which general by desktop as a runtime content?
1795
07-18-2016 07:35 AM
weiyang3
AlexanderNohe1
Occasional Contributor III
Take the *.geodatabase file off of your SD card and place it back on the computer from which you exported it.  Then you can use the Copy Runtime Geodatabase to File Geodatabase to get this back into a format that you can work with in ArcMap.
Here is the documentation for that tool:
Copy Runtime Geodatabase To File Geodatabase—Help | ArcGIS for Desktop
AlexanderNohe1
I am not really sure what you are asking.
Are you running a spatial analysis tool and wanting the output from that or are you looking to get your data from ArcMap to Android?
weiyang3
Thank you for replay for me.I Below I will describe my problem again:
Now, I have already created a .geodatabase runtime content data by arcmap's "share as.."menu,then I import this into my android phone's SD scard. and I can view and edit the data on android phone. But I have a question, is how I edit product export, shows in arcmap?
AlexanderNohe1
