Greetings, Issue connecting Collector for ArcGIS with Portal for ArcGIS
2164
8
07-20-2016 05:01 AM
MostafaMohamed
Recently I installed Portal for ArcGIS and added some editable layers for collectors to update. However, I can't connect to my Portal.
After entering server URL and credentials, I get redirected to the accounts form.
Also oftenly a message appears and states that the server URL cannot be verified.
attached two screenshots.
Thanks in advance.
Tags (1)
GISSupport3
Occasional Contributor III
Screen shots missing?
MostafaMohamed
Actually not, I see two images attached.
NeilAyres
Is this something to do with security certificates on the server?
What happens if you "Accept" the unverified server connection?
MostafaMohamed
Hi Neil,
After accepting the unverified server, I get the same result. However I installed fiddler and set it up as a proxy and I was able to connect to my Portal successfully. But I need to
figure out how to connect without using fiddler.
Any Ideas?
Also I need to access through 3G/4G .
NeilAyres
I am no expert on the setup of server and portal. So you must have done something wrong there.
Plus web adapters etc etc.
Sorry, no more advice from me....
BertKraan1
Like GIS Support, I can't see any pictures attached.
MostafaMohamed
oooh, How come I can see them. No problem I included them in this comment.
Thanks..
GISSupport3
Can see images now ...
During installation did you configure anything in:
https://<my.machine>:6443/arcgis/admin/machines/<my.machine>/sslcertificates
