Problem with clip script wich loops throught attributes of clipping layer
1811
07-20-2016 10:13 PM
JohannesBierer
Occasional Contributor III
Error message in script which worked correctly days before? Any ideas why?
line 16, in <module>
    quercy = field + "=" + "'" + Loop1 + "'"
TypeError: cannot concatenate 'str' and 'int' objects
import arcpy
import os
input = arcpy.GetParameterAsText(0)
clipfeature = arcpy.GetParameterAsText(1)
output = arcpy.GetParameterAsText(2)
clipfeature_Layer = "clipfeature_Layer"
arcpy.env.workspace = output
field = "BFN_NR"
inputSp = input.split(";")
arcpy.MakeFeatureLayer_management(clipfeature, clipfeature_Layer, "", "", "")
cursor = arcpy.SearchCursor(clipfeature)
for row in cursor:
    arcpy.AddMessage(row.getValue(field))
    Loop1 = row.getValue(field)
    arcpy.SelectLayerByAttribute_management (clipfeature_Layer, "NEW_SELECTION", quercy)
    Sel_shape = "Sel_" + Loop1 + ".shp"
    arcpy.CopyFeatures_management(clipfeature_Layer, Sel_shape)
    for i in inputSp:
        arcpy.AddMessage(i)
        arcpy.Clip_analysis(i, Sel_shape, "Clip_" + row.getValue(field) + "_" + i)
DanPatterson_Retired
quercy = field + "=" + "'""'" + str(Loop1) + "'"
just to ensure you have string values in case Loop1 returns a number
RebeccaStrauch__GISP
you could also try formatting it like this:
Loop1 = "somestring"
field = "BFN_NR"
quercy = ("{0} = '{1}'".format(field, Loop1))
print(quercy)
# returns...      BFN_NR = 'somestring'
that's how I usually do it anyway (and surprised Dan didn't mention that )
JohannesBierer
Attribute field must be a string defined field and it's all right
JohannesBierer
Doen't work with integer or number fields, obviously
