geoenrichment race data issue
2666
12
07-21-2016 11:48 AM
Dr_Carter
New Contributor III
Hi.
I just ran the enrich layer tool in ArcGIS Online for the DC area by adding the 2016 Black/African American Non-Hispanic Population (Esri) data, as well as others from the race options.
The problem is that the results appear to be percentages, not population counts. The highest black census tract has a value of 37, which could not be count data.
Is this an error? Is there any way to get the population count data, not percentages? I didn't see the option when selecting the data.
Thanks.
DanielStauning
Hi Chris,
Thanks for reporting this, we've been looking into it today and it seems that there are a handful of race & ethnicity variables which have an incorrect alias (the field alias is used for display in the table), and thus the table header in your previous screen cap shows incorrect names for some variables. We apologize for the inconvenience and will be patching this very soon. If possible we'd like to get you in touch with our technical support team so we can track this as a bug and provide the best possible assistance. We'll be reaching out to you again shortly.
-Daniel
DanielStauning
Hi Chris,
Is this variable you were using? Is it from the Race & Hispanic Origin category?
2016 Black/African American Population (Esri)
RaceAndEthnicity.Black_CY
This variable from the Race and Ethnicity Category is a percentage:
Black Alone
RaceAndEthnicity.Black_CY_P
Note that _CY means current year and _P means percentage. You can see the full variable name by hovering over the information icon
If you can provide a bit more info on the study areas you're using that would help also, do you have a layer of census tracts that you've added to the map?
-Daniel
Dr_Carter
New Contributor III
Hi Daniel,
Within Enrich Layer, in step 2 I Select Variables, then click Race and then all Race Variables. I expanded the "2016 Race and Hispanic Origin (Esri)" box, then selected "2016
Black/African American Non-Hispanic Population (Esri)".
From what I see there is nothing stating if it is percentage or count data. Another thing is, the "White Non-Hispanic Population (Esri)" value and the Non-Hispanic American Indian values seem like counts. Non-Hispanic Asian, as with blacks, has very low values and seem to be percentages. That's what makes me wonder if there is an error in the data.
Thanks for your help.
Dr_Carter
New Contributor III
Hi again Daniel.
I was just playing around with the geoenrichment again, to see if I can figure out what is happening with the count vs. percent data, and noticed another issue. As in the image below, you can see that the boxes that are checked did not select the correct variables.
Chris
DanielStauning
Hi Chris,
-Daniel
Dr_Carter
New Contributor III
Thanks Daniel and Fasil.
Could my original issue of some results appearing to be percentages rather than counts be related to this?
FasilTiru
Chris,
This is also related to the variables issue Daniel discussed above. I hope you received my emails that I sent from the case we created for you with all the details.
fasil
Dr_Carter
New Contributor III
Thanks Fasil.
Chris Carter, MBA, PhD
Professor of Geography.
Long Beach City College
FasilTiru
Chris,
This is Fasil from Support. A case has been created for you and you should receive an email with an update on this case. Please let me know if you have any follow up questions.
Fasil
Esri Support
DanielStauning
Chris,
This has been patched, please let us know if you see any further issues.
-Daniel
