Table to Excel export using python in ArcSDE
1885
07-21-2016 02:56 PM
DougMerrick
New Contributor III
I am wanting to (from Windows 10 desktop) to run a python script that exports the table from feature classes, within a feature dataset, in an ArcSDE environment. I can manually run the script in ArcMap everyday, but this will add to the tasks that I already have. I need the script to run outside of ArcGIS so I can automatically run the script with Scheduled Tasks in Windows.
I have created the connection file and can list feature datasets and classes but I cannot figure out how to use the arcpy "table to excel" tool on the feature datasets within feature classes.
What I have so far:
# Import arcpy module
import arcpy
from arcpy import env
import os
arcpy.env.workspace = "G:\Location_of_Connection.sde_file"
Utility_Pipe = "Utility_pipe_???_Unsure how to point directly at the FC in SDE"
Utility_xls = "Location of Utility Excel\Utility.xls"
# Process: Table To Excel
arcpy.TableToExcel_conversion(Utility_Pipe, Utility_xls, "NAME", "CODE")
print "done"
I using ArcMap 10.3.1 in an enterprise geodatabase on windows 10.
Thanks!
DanPatterson_Retired
If you have done it manually, perhaps you can use the information in the Results window
Using the Results window—Help | ArcGIS for Desktop
maybe even exporting to a python snippet
DougMerrick
New Contributor III
I looked at that before realizing that by using a python script to run the model itself would reduce the coding headache significantly.
The python script to run the model can be found here http://joelmccune.com/run-models-as-scheduled-tasks/
When making the model, add the data directly from the source (ie. NCGIS.GIS.UtilityMain instead of from the table of Contents-Utility Main).
CCWeedcontrol
Occasional Contributor III
Table to Table (Conversion)
import arcpy
fc
= r'C:\path\to\your\fc'
outtable
= r'C:\temp'
arcpy
.TableToTable_conversion (fc, outtable, 'outtableFile.dbf')
DougMerrick
New Contributor III
I was able to get this to work on local data, but pointing the fc to the specific feature class in the versioned ArcSDE environment was proving troublesome. So I went with the solution I detailed above.
Thanks though
