Hi,I got some progress on the InfoWindow and now there is a moOver an mouseOut events that should open it, but whe you put your mouse on the symbol it starts flickering because it's executing mouseOver and mouseOut endlessly. Maybe it's too sensitive and you have to be exact on the point. Does anyone have an idea how to modify the mouse events to make them "less sensitive" or something? Here is the modified code:<?xml version="1.0" encoding="utf-8"?>
<mx:Application
xmlns:mx="http://www.adobe.com/2006/mxml"
xmlns:esri="http://www.esri.com/2008/ags"
layout="horizontal"
pageTitle="3 / query by extent"
initialize="initApp()">
<mx:Script>
<![CDATA[
import mx.effects.Glow;
import mx.events.EffectEvent;
import mx.events.ListEvent;
import com.esri.ags.Graphic;
import com.esri.ags.events.DrawEvent;
import com.esri.ags.events.ExtentEvent;
import com.esri.ags.geometry.Extent;
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.tasks.Query;
import com.esri.ags.tasks.FeatureSet;
import mx.collections.ArrayCollection;
import mx.controls.Alert;
import mx.rpc.AsyncResponder;
import mx.managers.ToolTipManager;
private function initApp():void {
ToolTipManager.showDelay = 0;// Display immediately.
[Bindable] private var hashmapOfExistingGraphics : Object=new Object();
private function onExtentChange(event:ExtentEvent):void
query.geometry = myMap.extent;
queryTask.execute(query, new AsyncResponder( onResult, onFault ));
private function onResult( featureSet : FeatureSet, token : Object = null ) : void
for each ( var myGraphic : Graphic in featureSet.features )
// only add features that are not already in the graphics layer
var graphicID:String=myGraphic.attributes.HotSpot + "." + myGraphic.attributes.FID;
if ( ! hashmapOfExistingGraphics[graphicID] )
// New feature (not already added to graphics layer
hashmapOfExistingGraphics[graphicID]=1;
myGraphic.symbol = defaultSymbol;
myGraphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOver);
myGraphic.addEventListener(MouseEvent.MOUSE_OUT, onMouseOut);
myGraphic.id = graphicID;
myGraphic.toolTip = myGraphic.attributes.CITY_NAME;
myGraphicsLayer.add( myGraphic );
var extent : Extent = myMap.extent;
var graphic : Graphic;
var results : ArrayCollection = new ArrayCollection;
for (var i : Number = 0 ; i < myGraphicsLayer.numChildren ; i++)
graphic = myGraphicsLayer.getChildAt(i) as Graphic;
trace("GG:" + graphic.geometry );
if (extent.contains(MapPoint(graphic.geometry)))
results.addItem(graphic.attributes);
dg.dataProvider = results;
private function onFault( info : Object, token : Object = null ) : void
Alert.show( info.toString() );
public function onMouseOver( event : MouseEvent ) : void
var graphic : Graphic = event.currentTarget as Graphic;
graphic.symbol = myInfoSymbol;
public function onMouseOut( event : MouseEvent ) : void
//var graphic : Graphic = event.currentTarget as Graphic;
//graphic.symbol = highlightedSymbol;
Graphic( event.target ).symbol = highlightedSymbol;
//myGraphicsLayer.clear();
private function onItemRollOver( event : ListEvent ) : void
var gr: Graphic = findGraphicByAttribute(event.itemRenderer.data)
gr.symbol = highlightedSymbol;
var glow:Glow = new Glow(gr);
glow.duration = 2000 ;
glow.alphaFrom = 1 ;
glow.alphaTo = 0 ;
glow.blurXFrom = 10 ;
glow.blurXTo = 0 ;
glow.blurYFrom = 20 ;
glow.blurYTo = 0 ;
glow.strength = 100;
glow.color = redFill.color;
glow.play();
private function onItemRollOut( event : ListEvent ) : void
findGraphicByAttribute(event.itemRenderer.data).symbol = defaultSymbol;
public function findGraphicByAttribute( attributes : Object ) : Graphic
for each( var graphic : Graphic in myGraphicsLayer.graphicProvider)
if ( graphic.attributes["CITY_NAME"] == attributes["CITY_NAME"])
return graphic;
return null;
public function findInList( graphic : Graphic ) : int
for each( var attributes : Object in dg.dataProvider )
if (attributes === graphic.attributes)
return (dg.dataProvider as ArrayCollection).getItemIndex(attributes)
return -1;
</mx:Script>
<esri:SimpleFillSymbol id="redFill" alpha="0.5" color="0xFF0000"/>
<!-- setup stuff -->
<esri:QueryTask id="queryTask" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0"/>
<esri:Query id="query" outFields="CITY_NAME, STATE_NAME, ELEVATION, FID" returnGeometry="true" />
<esri:SimpleMarkerSymbol id="defaultSymbol" color="0x0000FF" style="triangle" size="20" />
<esri:SimpleMarkerSymbol id="highlightedSymbol" color="0xFF0000" style="triangle" size="20" />
<esri:InfoSymbol id="myInfoSymbol">
<esri:infoRenderer>
<mx:Component >
<mx:VBox label="{data.CITY_NAME}" backgroundColor="0xEEEEEE">
<mx:Label text="Name: {data.CITY_NAME}"/>
<mx:Label text="State: {data.STATE_NAME}"/>
<mx:Label text="Elevation: {data.ELEVATION}"/>
</mx:VBox>
</mx:Component>
</esri:infoRenderer>
</esri:InfoSymbol>
<!-- visual stuff -->
<esri:Map id="myMap" extentChange="onExtentChange(event)">
<esri:extent>
<esri:Extent xmin="-125.9" ymin="44.6" xmax="-114.6" ymax="50.2">
<esri:spatialReference>
<esri:SpatialReference wkid="4326"/>
</esri:spatialReference>
</esri:Extent>
</esri:extent>
<esri:ArcGISTiledMapServiceLayer
url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
<esri:GraphicsLayer id="myGraphicsLayer"/>
</esri:Map>
<mx:VBox width="260" height="100%" backgroundColor="#FCFCFC" fontWeight="bold">
<mx:DataGrid id="dg" width="100%" height="100%" itemRollOver="onItemRollOver(event)" itemRollOut="onItemRollOut(event)">
<mx:columns>
<!-- <mx:DataGridColumn dataField="Cities In View Extent" /> -->
<mx:DataGridColumn headerText="City Name" dataField="CITY_NAME"/>
</mx:columns>
</mx:DataGrid>
</mx:VBox>
</mx:Application>
