How do I access or download my data from the collector app to my desktop?
2057
07-22-2016 05:33 AM
TanyaDeOliveira
I have successfully uploaded and used the collector app to make edits in the field using an existing shapefile layer. Now that I am back in the office, I would like to download or access this layer to use, edit and store on ArcGIS desktop. When I access this map in the "My Contect" portion of ArcGIS Online, the map shows the layer in the unedited version - what the layer looked like before I completed my field work. How can I get the edited version of this layer? It's shapefile layer with points and a small attribute table.
JeffSegal
New Contributor III
Hi Tanya,
Once you complete the SYNC operation on Collector, the edited data should be seen on ArcGIS Online.
AdrianWelsh
MVP Honored Contributor
Hi Tanya,
I had a similar issue where my collected data never showed up on when I synced. I never came to a resolution (though, I should call Esri support on it at some point).
Can't sync offline Collector map
