Legend Text in Embeded Webmap not Showing on Dark Theme
2061
07-22-2016 08:28 AM
deleted-user-W17i9rKaOdiH
When I share my web map by embedding it in a website from the map viewer, if I select the dark theme, my legend text is not showing. I assume this is because my text is black and the legend is black because if I select the light them, I can see the text.
In addition, my details text shows up fine with the dark theme, so I am baffled as to why the legend text is not adjusting to the dark theme option.
My question is: Why is this not adjusted in the Legend box or is there any way I can adjust the font color for the legend in my embedded map?
The only alternative is to select the light theme, which I don't find very attractive.
Has anyone else seen this?
Tags (3)
KellyHutchins
Esri Frequent Contributor
This is a bug with the dark theme that will be fixed in the next release of ArcGIS Online.
KellyHutchins
Thanks, Kelly. When is next release?
carlynne
