Query widget buffer distance is inaccurate
1930
5
07-22-2016 12:18 PM
ScottKiley
Occasional Contributor II
The Web AppBuilder Query widget's buffer distance is inaccurate for me. The distance is about 36.5% too short. For example when I enter a distance of 300' and then measure the buffer, it's actually only about 220'. The "Near Me" and "Situational Awareness" widgets both create accurate buffers when configured for the same app, so I'm guessing it's something with the query widget. Is there something in the Query widget configuration I'm missing that can help me with this?
QunSun
by Esri Contributor
Scott,
This bug is fixed on ArcGIS Online version.
WAB developer edition 2.2 will be released in weeks.
ScottKiley
This image shows a buffer that should be 1,320' but only measures about 951'.
Here is a link to the app:
http://citywd.maps.arcgis.com/apps/webappviewer/index.html?id=72c1321a9a7045e7abc80e2d6c46b075
QunSun
by Esri Contributor
Hi Scott,
It is a bug of Query. We will fix it in next release.
ScottKiley
Thanks Qun Sun​! Do you have an idea when that release will occur?
QunSun
by Esri Contributor
Scott,
DerekLaw
Esri Esteemed Contributor
Hi Scott,
FYI, Web AppBuilder for ArcGIS Developer Edition v2.2 is now available,
https://blogs.esri.com/esri/arcgis/2016/10/12/web-appbuilder-for-arcgis-v2-2-developer-edition-now-a...
Hope this helps,
