Webmaps - a 'turn all popups on' button
1853
6
07-25-2016 10:47 AM
by Anonymous User
Not applicable
     I know changing layer order or number of layers completely ruins a webmap and removes all its popups but this time just changing the name in one layer in the mxd's TOC mulched it. I had thought that was fine, I think I remember doing it before and being ok. No!  Seriously we need a "turn all popups on" button for a service, in the webmap in AGOL. It would save days a year clicking Enable Popup.. then waiting, because it snaps all the way to the top, and then back down... then up.. then down.  Yes Server 10.3 allegedly fixes the layerID thing but still.. for us poor souls on 10.2 and below a turn all popups on would be so, so nice.
DanPatterson_Retired
perhaps you might want to consider posting an idea ArcGIS Ideas
AdrianWelsh
MVP Honored Contributor
Dan, it looks like the issue may be solved by upgrading to 10.3 or beyond for ArcGIS Server
I am thinking that other than upgrading, the only solution is to do all the manual and painful labor... (Or hire a intern or cheap college student to do it...)
by Anonymous User
Not applicable
Good idea, pun intended. Created: https://community.esri.com/ideas/12405
With 103. this would still be helpful, if you initially want to turn popups on for all layers ( a very likely, if not the most likely, use case) and have dozens or hundreds of sublayers (not that uncommon) it's still a chore, and it snaps to the top each time.
by Anonymous User
Not applicable
This is Assumed Answered but remains an issue -- Esri will it get Consideration?  It remains a large portion of time I spend creating sites in WebApp Builder, hours of clicking "Enable Popup".
since it isn't a bug... but an enhancement request, then you can only support the idea, but that would be for current versions..., 10.2 I think has reached the end of its life cycle.  I suspect when the 'support' gets into the 'gray zone', you can't expect enhancements or back porting of functionality.
Esri Support 10.4 (10.4.1)
by Anonymous User
Not applicable
This is not related to server versions.   Yes, it would be far more useful to us with 10.2 - but it would also be very useful when first publishing a service with hundreds of layers with 10.4.
