Lines disappear when editing
3185
07-25-2016 06:13 PM
JenniferDeRose
I have been able to create point, line, and polygon data on numerous projects until today. I was able to draw numerous line feature classes in a couple of different geodatabases. I started drawing some line info in a different database and it disappeared but the shape info is reflected in the attributes box. I started drawing a line in another database and it showed for awhile. I switched back and forth between two different line layers in the same database and it was fine. When I finished half of the lines disappeared while the other half were visible. I have tried deleting the feature classes all together, renaming them, changing the symbols, and exiting ArcMap over and over. Nothing has worked. Any suggestions?
DanPatterson_Retired
by chance, if the layer has been symbolized at one point, it is likely that symbol/color/etc for no data has not been assigned so you just can't see it.  If the record appears in the table and can't be seen on screen, then that is the first place to visit
JenniferDeRose
Thanks. It was actually a bad msd file. I added data to a new one and it works.
To: Jennifer DeRose <jenniferderose@yahoo.com>
Sent: Monday, July 25, 2016 7:36 PM
Subject: Re: - Lines disappear when editing
#yiv5469445610 * #yiv5469445610 a #yiv5469445610 body {font-family:Helvetica, Arial, sans-serif;}#yiv5469445610 #yiv5469445610 h1, #yiv5469445610 h2, #yiv5469445610 h3, #yiv5469445610 h4, #yiv5469445610 h5, #yiv5469445610 h6, #yiv5469445610 p, #yiv5469445610 hr {}#yiv5469445610 .yiv5469445610button td {}
GeoNet
reply from Dan Patterson in Community Help - View the full discussionby chance, if the layer has been symbolized at one point, it is likely that symbol/color/etc for no data has not been assigned so you just can't see it.  If the record appears in the table and can't be seen on screen, then that is the first place to visit
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Community Help by email or at GeoNet
Following Lines disappear when editing in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
MatthewDuffy
Occasional Contributor II
I was going to mention double-checking definition queries and editing templates, but I'm glad you figured it out.
