clip to shape
1815
07-25-2016 08:24 PM
王伟
How can i use python to set the dataframe's range as a shapefile,hope for you reply
RebeccaStrauch__GISP
Check out the thread Create a polygon from data frame which has several options for creating a polygon from an extent.
Darren Wiens code (copied below) might be you simplest solution, just need to change the output to a shapefile.
mxd = arcpy.mapping.MapDocument("CURRENT") # map
df = arcpy.mapping.ListDataFrames(mxd)[0] # get 1st data frame
sr = df.spatialReference # get spatial reference
ext = df.extent # extent object
BL = arcpy.Point(ext.XMin,ext.YMin) # bottom left
BR = arcpy.Point(ext.XMax,ext.YMin) # bottom right
TR = arcpy.Point(ext.XMax,ext.YMax) # top right
TL = arcpy.Point(ext.XMin,ext.YMax) # top left
df_poly = arcpy.Polygon(arcpy.Array([[BL,BR,TR,TL,BL]]),sr) # create polygon
arcpy.CopyFeatures_management(df_poly,r'in_memory\poly') # write to disk
If that is not what you are trying to do, you may need to supply additional information (Desktop or Pro, version, etc)
NeilAyres
Do you have any experience of writing geometries?
Start here :
Writing geometries—Help | ArcGIS for Desktop
And see the various properties of the data frame in the mapping module.
ArcGIS Help 10.1
