Esri Maps Web Part Work Flow Failing
512
07-26-2016 07:17 AM
MaryEllen_Perko
Occasional Contributor II
Hi.  I am trying to set up a Esri Maps workflow on a Sharepoint List that adds a polygon shape location to the list items.  The feature layer is hosted in AGOL and is owned by the sharepoint app config account.  When I start the work flow, the workflow is canceled by the "System Account" with the error: "Your WorkFlow failed: The server token is null."
Also, if I execute the workflow on an individual item/row in the table, the status is "Completed" but there is no shape.  The list I'm using is an export of the attribute table of the feature layer so there should be a match between the two.
Does anyone have any ideas where our configuration is wrong?
Thanks.
