How to open new survey in survey123 connect
1655
07-25-2016 06:27 PM
deleted-user-hslZ-nVMBX2A
New Contributor III
Is is possible to open a new survey that I started creating on the web  in survey123 connect?
JamesTedrick
Esri Esteemed Contributor
Hi Nicole,
Yes, it is supported.  When you login via the Survey123 Connect application, you will see both the surveys you've authored in Survey123 Connect and the Survey123 website.
IsmaelChivite
Esri Notable Contributor
Hi. Not at the moment, but we are working towards making this possible in an upcoming release.
Nicole_Ueberschär
Is this supported now?
JamesTedrick
Hi Nicole,
Nicole_Ueberschär
Thanks James, found it!
