Offline App Need Internet
1310
07-26-2016 01:40 AM
FurkanERYILMAZ
Hi Everyone;
Firstly, I'm newbie in GIS Works. I'm trying develop simple offline map application. As a beginning only showing map for test data like San Francisco.tpk basemap is enough for me. I have downloaded SanFrancisco.tpk and run application which it need internet connection. If I allow internet connection app trying to connect  Arcgis Server Street Maps. If I'm not only black screen I got. I have any written connection code Arcgis Server. How can i prevent this issue and success to show basemap ? Am i wrong way trying to show basemap ?
Best regards...
AlexanderNohe1
Occasional Contributor III
What I would do is sideload the San Fransisco.tpk onto the device and then in the onCreate method in your activity, add the layer of the Offline TPK and load it while zooming to the extent.
This example should be sufficient for your needs:
arcgis-runtime-samples-android/OfflineEditorActivity.java at master · Esri/arcgis-runtime-samples-an...
FurkanERYILMAZ
Thanks. I will try immediately this sample.
AlexanderNohe1
Hello Furkan ERYILMAZ​,
Did the above help resolve your issue?
