using the field calculator with python
3813
07-27-2016 11:41 AM
LeifJohnson
So i am trying to use the field calculator using python to determine the input for the field. So for example my table has 2 fields(both text fields(one of the fields would be empty at this point)), i would like the code to say If field one is "String 1" then put in field 2 "string 2". Basically i want it to check the value of field one and if it matches the string i am looking for then i want it to write another string that i decide in the code to write. I was wondering if  someone had a template of a similar code that i can look at to get an idea on how to write it. Preferable in python but i think VB works also. Thanks in advance
DanPatterson_Retired
the best bet would be to either show the code you are trying to implement or show the field calculator syntax you are using since your description is a bit of both
DarrenWiens2
MVP Honored Contributor
See the third example on this page, which uses if-then logic in a code block: Calculate Field—Help | ArcGIS for Desktop
FC_Basson
MVP Regular Contributor
So you basically want to calculate Field 2 based on the value in Field 1
Your Python code block can look like this:
def calcfield(field1):
   val = ""
   if field1 == "test":
      val = "string 2"
   else:
      val = "other string"
 return val‍‍‍‍‍‍‍‍‍‍‍‍‍‍
And the field calculation expression:
Field2 =
calcfield(!MyField!)
