Create GIS Server connection to ArcGIS online
1663
07-27-2016 12:37 PM
MichaelPorter1
New Contributor III
I can create a read only GIS Server connection to ArcGIS online with the URL:
http://services3.arcgis.com/A6Zjpzrub8ESZ3c7/arcgis/rest/services
but when I try and create a publish service with the same url it fails. Any ideas?
KellyGerrow
Esri Frequent Contributor
I think you are using ArcMap and trying to publish to ArcGIS Online. To do this, Sign into ArcGIS Online from File> Sign in and then follow the steps outlined in this documentation: Publish hosted feature layers—ArcGIS Online Help | ArcGIS
-Kelly
MichaelPorter1
New Contributor III
Yes but what if I want to login programmatically so I can put in script? Only works if I connect as described below its fine but can't change user in script.
Sent from my iPhone
KellyGerrow
Hi Michael,
There are a few ways to go about scripting publishing. You can try this by scripting direct rest calls using the rest API and using arcpy to create the SD file.
Check out the following github repo for a sample using arcpy and  Rest API calls ​This script generates a token for authentication and then add's an item and publishes the item.
-Kelly
