How do I add a new feature to an existing featureclass
1609
07-27-2016 05:25 PM
LeeNeher1
I do a lot of selecting and updating, but I just want to write a new feature (add a row) based on values from another feature class
DanPatterson_Retired
You could play with the arcpy.da.editor Editor—Help | ArcGIS for Desktop
or just the da.insertcursor option InsertCursor—Help | ArcGIS for Desktop
depends on what you want to do, there are other options depending on where you data are (aka merge)
LeeNeher1
Thanks, I am working with big (4-6gb) feature classes and a simple load in ArcCatalog fails.   I will check out insertCursor.
NeilAyres
Why does load fail? What is the error? It should work.
Are the input and target the same type / coord sys / attributes???
da.InsertCursor will also work, but that seems a long way around to do what the standard tools will do.
