Can I have ArcGIS 10.3.1 and ArcGIS Pro installed and running in the same computer?
4886
6
07-27-2016 04:38 PM
VladimirGarcia
I have a lot of MXDs but at the same time I would like to start working with ArcGIS Pro without having to uninstall the ArcGIS 10.3.1. is it possible to have both running?
XanderBakker
Esri Esteemed Contributor
Installs for ArcMap and ArcGIS Pro are independent. So yes you can have ArcMap 10.3.1 and ArcGIS Pro (any version) installed on the same computer.
DanPatterson_Retired
yes but I am not sure of the mix of your ArcMap version with the Pro version.
It would be best if you pair them, I am using 10.4.1 and 1.3.  Check with your software availabilitty in your organization o see if you can upgrade, but I did run 10.3.1 and 1.2 (I think) with no problems
ArcGIS 10.4.x for Desktop system requirements—ArcGIS Help | ArcGIS for Desktop
ArcGIS Pro 1.3 system requirements—ArcGIS Pro | ArcGIS for Desktop
XanderBakker
NeilAyres
Just don't try and run them at the same time unless you have a huge amount of memory
JoshuaBixby
MVP Esteemed Contributor
When it comes to ArcGIS Pro, that statement applies whether one is talking about ArcMap or any other application.
AdrianWelsh
MVP Honored Contributor
Vladimir,
Like Xander said, they're independent. I currently have ArcGIS Desktop 10.3.1 (ArcMap) and ArcGIS Pro 1.3. I use them both and both work fine. Like Neil said, make sure you have the memory! Pro likes to make my machine sound like it's about to go into orbit...
I am not sure the advantage of pairing them like Dan said. I have elected to keep 10.3.1 since I have had very little problems with it. I use Pro 1.3 for it's newer abilities (which some have been implemented into 10.4 and 10.4.1 but I have not upgraded my ArcMap - maybe I will soon...).
On my system, with the same project etc loaded in an idle state, Pro takes about 4.5 X the memory of ArcMap
but Edge takes up a big chunk as well.
