Points created in excel keep projecting at the equator
2425
10
07-28-2016 08:18 AM
EmmaFlanagan
I have created a list of points in excel with X and Y co-ordinates. The co-ordinates are in WGS 1984. When I bring them into ArcGis (I'm using version 10.4.1) they keep projecting at 0,0 (so basically the equator). The points are meant to be in Ireland. I can see by the shape of them they are projecting in roughly the right order. Nothing I do seems to make them project in the right location. Does anyone have any idea how to make them project correctly?
TIA
BenjaminMittler
Occasional Contributor III
When in data view in the bottom there should be x and y values and a unit. What is the unit associated with these values? You could also check the data frame properties for this same unit.
ChrisDonohue__GISP
Another item to help in troubleshooting - check the Properties of the Data Frame to see what it is using.  It may be that the Data Frame is set to an inappropriate coordinate reference system.  Keep in mind the Data Frame "inherits" its coordinate reference system from the first layer loaded into ArcMap (and if the first layer loaded in had an Undefined reference system, the Data Frame will be Undefined).
Chris Donohue, GISP
DarrenWiens2
MVP Honored Contributor
It sounds like you've got lat/long coordinates (degrees) that are being assigned a coordinate reference system measured in some other unit (probably meters). Can you show the coordinate reference system you assign in the Display XY dialog box? It should be plain, old, geographic GCS_WGS_1984 (i.e. not projected).
RebeccaStrauch__GISP
Make sure you don't have the X (longitude) and Y (Latitude) reversed, and the Latitude longitude as negative if in the western hemisphere.  Also, deicmal degrees work best.
edit: and if you are reading them in as an event theme, make sure to specify the WGS 84 as the coordinate system in the wizard.
edit2:  Melita Kennedy   Thanks for the catch....yaaa...I know better....just a typo, but fixed now.  I'll blame it on my keyboard having issues today with cut-n-paste.
MelitaKennedy
Esri Notable Contributor
<psst> "longitude" in western hemisphere
AbdullahAnter
When you use Add X & Y Data tool , make sure that you choose the correct spatial reference ( WGS 84 similar to excel sheet coordinate).
EmmaFlanagan
Thanks for the comments and help.
I can confirm it is projected in WGS84. The Co-ordinates are in decimal degrees, and include a negative latitude. The co-ordinates are all in the region of 53 (longitude) and -8 (latitude) which would be correct for Ireland. In order to make sure its not picking up any issues from a projection system on a different co-ordinate system I've projected them on the OpenStreet Map basemap which as far as I'm aware uses WGS84.
The units of the data view are in meters. I've checked the data frame extent and it appears to be set at 0. Below is a screen shot of the layer properties.
DanPatterson_Retired
well a sample of the data as suggested would be in order since you appear to be floating in single precision space near the equator where your bounds are nearly equal.  I would suggest posting a sample of the data since the extents of your geodatabase are just wrong.
EmmaFlanagan
Fair enough. Here is a screen shot of my attribute table.
In case its important, I'm using a basic licence.
