Can I link the ObjectIDs to the FIDs?
1528
5
07-29-2016 06:30 PM
RaylaLiu
I have 2 dataset, A (origin) and B (destination). Each dataset has a variable called FID, which helps me to identify observations. I am creating an OD cost matrix. To do that, I load locations as origins and destinations. Now, the attribute tables for origins and destinations include ObjectID and Name. However, none of those corresponds to the FIDs I have in the original dataset. Is there a way I can link the ObjectIDs back to the FIDs, or identify my observations?
Thanks in advance!
Tags (1)
DanPatterson_Retired
did you run the OD matrix? and open the table OD cost matrix analysis—Help | ArcGIS for Desktop
The table conents indicate what is what
RaylaLiu
Yes, I ran the OD matrix. I understand how items in the OD cost table link back to the OriginID and DetinationID. Those two IDs are generated when I am loading locations. The problem is that those two IDs are not the same as the FID given when I imported my dataset. For example, OriginID starts from 1, while FID in the original file starts from zero.
if you look in the original tables, for example in a gdb, you will see that is the case.  In shapefiles, OID is generally set to 0 whereas FID is unique, although OID can be calculated to be = to FID or incremented by one. So when interpreting the result of the OD table, you need to know how the input table indices are formed
RaylaLiu
That is my guess, in the OD table, FIDs don't show up, only OIDs do. I believe OID = FID + 1. At least, OID and FID have the same order. Thank you very much for your reply!
MelindaMorang
When you add/load your origins and destinations, you can use field mapping to transfer data from your original input points into the Origins and Destinations sublayers of the OD layer.  You could transfer your FID values into the Name field, or you could use the Add Field To Analysis Layer tool to add a new field (call it "Orig_FID" or something) and then map your FID into that new field.
