Authentication Portal cannot be reached (firewall issue)
2430
8
08-02-2016 01:08 AM
GeorgieCassar
At work I get this error when opening Drone2map.
I can open drone2map successfully from my home laptop where I am using wifi.
Is there a domain I can add to our firewall white list to enable this authentication portal to be reached ?
KristaHeinrich2
New Contributor III
Thanks Tony,
That did it, it was a combo of the *arcgis.com and the *esri.com that needed to be whitelisted.
Cheers,
Krista
RakeshModi
I am having same problem after successful installation --
GeorgieCassar
Rakesh
I resolved the issue by uninstalling Drone2Map, downloading the latest version of the software and reinstalling.  They have fixed this problem with the last release it appears.
GeorgieCassar
I take that back.  It's not working again so will attempt to white list the URLs.
KristaHeinrich2
New Contributor III
This does not appear to have been fixed in the trial version. I downloaded version 1.0.1 today and am still receiving that same error.. any word on when this will be fixed?
AnthonyMason
Krista,
Could you try to whitelist the following ArcGIS domains:
•http://*.arcgis.com <http://%2A.arcgis.com/>
•https://*.arcgis.com <https://%2A.arcgis.com/>
•http://*.arcgisonline.com <http://%2A.arcgisonline.com/>
•https://*.arcgisonline.com <https://%2A.arcgisonline.com/>
•http://*.esri.com <http://%2A.esri.com/>
•https://*.esri.com <https://%2A.esri.com/>
Tony
KristaHeinrich2
New Contributor III
Thanks Tony,
Cheers,
Krista
MohamedHamoud
I have the same problem, but I couldn't find the right way to whitelist a domain. Can you please explain the steps of whitelisting the required domains?
KristaHeinrich2
New Contributor III
Hi Mohamed, I had to speak to my IT department as they were blocking the domains through their security set up. Unfortunately it wasn't something i resolved myself  so i don't have details.
