Making areas of same properties different colors
1266
08-04-2016 02:21 AM
RolfLund
Hey guys.
I have a data file containing a lot of different information, but I need to do something that might seem basic; I need to divide specific areas by colour. I have 500 areas and I have 4 values that these areas can be (very low income, low income, high income and very high income). I need to tell ArcGIS pro something like this: by cluster number, fill cluster with colours for income level.
Thank you in advance
DanPatterson_Retired
are you talking about symbolization
Symbolization—ArcGIS Pro | ArcGIS for Desktop
for example
Unique values—ArcGIS Pro | ArcGIS for Desktop
but there are many options to explore
XanderBakker
Esri Esteemed Contributor
If your polygon layer contains a field with the cluster number, you could set a definition query to filter a single cluster and use the Graduated symbols—ArcGIS Pro | ArcGIS for Desktop or Unique values—ArcGIS Pro | ArcGIS for Desktop  as Dan already suggested, to visualize the income classes. You should replicate the layer for each cluster. Each cluster could have a different color ramp to distinguish the cluster and at the same time show the income levels.
