LocalMapService internal exception
1301
08-05-2016 04:15 PM
MichaelKnight
Hi Guys,
I have been encountering some serious issues with the LocalMapService class in the 10.1.1 API for Java. I get an internal socket exception being thrown  within the ESRI code when I stop them. Has any one else experienced this?
Code Sample:
m_localMapService = new LocalMapService(BLANK_MPK_PATH);
m_localMapService.setEnableDynamicLayers(true);
m_localMapService.start();
m_localMapService.stop(); // Internal exception thrown
Exception:
java.net.SocketException: Software caused connection abort: recv failed
  at java.net.SocketInputStream.socketRead0(Native Method)
  at java.net.SocketInputStream.socketRead(Unknown Source)
  at java.net.SocketInputStream.read(Unknown Source)
  at org.apache.http.impl.io.AbstractSessionInputBuffer.fillBuffer(AbstractSessionInputBuffer.java:130)
  at org.apache.http.impl.io.SocketInputBuffer.fillBuffer(SocketInputBuffer.java:127)
  at org.apache.http.impl.io.AbstractSessionInputBuffer.readLine(AbstractSessionInputBuffer.java:233)
  at org.apache.http.impl.conn.DefaultResponseParser.parseHead(DefaultResponseParser.java:98)
  at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:210)
  at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:271)
  at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:227)
  at org.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:209)
  at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:292)
  at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:126)
  at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:483)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:731)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:709)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:700)
  at com.esri.core.internal.io.handler.l.a(Unknown Source)
  at com.esri.client.local.LocalService.deleteService(Unknown Source)
  at com.esri.client.local.LocalService$d.run(Unknown Source)
  at com.esri.client.local.LocalService.stop(Unknown Source)
  at com.synectics.synergyii.gis.esri.runtime.PersistentLayerManager.loadImageLayers(PersistentLayerManager.java:88)
  at com.synectics.synergyii.gis.esri.runtime.RuntimeCONST.initalise(RuntimeCONST.java:108)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at com.synectics.synergyii.utils.JVMUtils.exectuteStaticMethod(JVMUtils.java:108)
  at com.synectics.synergyii.utils.JVMUtils.exectuteStaticMethod(JVMUtils.java:96)
  at com.synectics.synergyii.synergygis.SynergyGISPanel.<clinit>(SynergyGISPanel.java:103)
  at java.lang.Class.forName0(Native Method)
  at java.lang.Class.forName(Unknown Source)
  at com.synectics.synergyii.gui.MapWindow.initialise(MapWindow.java:1704)
  at com.synectics.synergyii.gui.MapWindow.<init>(MapWindow.java:390)
  at com.synectics.synergyii.gui.initialise.ClientInitialise.createApplicationWindow(ClientInitialise.java:637)
  at com.synectics.synergyii.gui.initialise.ClientInitialise.logon(ClientInitialise.java:838)
  at com.synectics.synergyii.gui.initialise.PasswordEntry.actionPerformed(PasswordEntry.java:704)
  at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
  at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
  at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
  at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
  at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
  at java.awt.Component.processMouseEvent(Unknown Source)
  at javax.swing.JComponent.processMouseEvent(Unknown Source)
  at java.awt.Component.processEvent(Unknown Source)
  at java.awt.Container.processEvent(Unknown Source)
  at java.awt.Component.dispatchEventImpl(Unknown Source)
  at java.awt.Container.dispatchEventImpl(Unknown Source)
  at java.awt.Component.dispatchEvent(Unknown Source)
  at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
  at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
  at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
  at java.awt.Window.dispatchEventImpl(Unknown Source)
  at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
  at java.awt.EventQueue.access$500(Unknown Source)
  at java.awt.EventQueue$3.run(Unknown Source)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
  at java.awt.EventQueue$4.run(Unknown Source)
  at java.awt.EventQueue.dispatchEvent(Unknown Source)
  at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
  at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
  at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
  at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
  at java.awt.EventDispatchThread.run(Unknown Source)
nita14
Occasional Contributor III
Micheal,
do you stop the service after it has been started? Use  addLocalServiceStartCompleteListener to ensure that.
Regards,
Adam
MichaelKnight
Hi Adam,
I was under the impression that start was a blocking call therefore removing the need for callbacks?
Mike
nita14
I am not 100% it will resolve your issue, but I have already seen this kind of errors....Worth trying...
Adam
