NDVI Checkbox Not An Option
1564
08-05-2016 06:20 PM
RuwanNanayakkara
I am trying to process images from a DJI Phantom with a lens outfitted for NDVI coloration.  I was able to process normal RGB images from the same drone, and am able to get to the point to processing the NDVI images, but am not able to actually check the box to do so.  Any guidance is great, thank you.  Enjoying my first experience with the software except for this.
AnthonyMason
Ruwan,
Drone2Map will detect if your imagery has the necessary bands to create an NDVI image, and allow you to check the NDVI box. It sounds like in this case it is not picking up your NIR band correctly.
Would you be able to share a sample of this imagery so we can have a look at what is going on?
Tony Mason
Product Manager - Drone2Map
RuwanNanayakkara
Hi Tony,
I created a dropbox folder and emailed you the link, as requested.
DarioFinderle
Ruwan,
did you figure it out how to set Drone2Map to work with DJI Phantom modiefied lenses? Was there any progress?
