Map is not apperad
3099
8
08-09-2016 02:32 AM
YusukeInakazu
I will migrate an app WindowsXP to Windows7.
I deployed AerialPhoto_Catalog.dbf and XXX.jp2 in place.
Reading flles is successful maybe.
But,map is not shown.Map is "white".
Should I do this?
Old environment
  • OS:WindowsXP
  • ArcGIS:9.2
New environment
  • OS:Windows7(32bit)
  • ArcGIS:10.3.1
Thank you.
Ina
YusukeInakazu
IFeature feature = featureCursor.NextFeature();
I confirmed that "feature" is null.What is wrong?
by Anonymous User
Not applicable
Please check below thread and reset you local profile
https://community.esri.com/thread/78692
After add base maps.
if you still facing issue in ArcGIS desktop clean cache of which stotred locally on your system.
HiroshiORUI
この ArcGIS 開発者コミュニティは、日本の開発者を対象に運営を行っています。そのため、日本語で返信します。
ESRIジャパンとしましては、開発に関する問い合わせは有償の「開発者サポート」での対応することになっているため、開発に関する詳細な回答を行うことはできませんが、他の開発者の皆さんが回答しやすいように、もう少し状況の詳細が分かるといいと思います。
例えば、「アプリでは dbf ファイルからどのように GIS データを作成している」、「Map にどのようにデータを追加している」などです。
早急に回答が必要な場合には、弊社の開発者サポートをご検討ください。また、米国 Esri 社が運営する ArcObjects SDK のコミュニティ グループも GeoNet にはございますので、そちらもご検討ください。
by Anonymous User
Not applicable
Can you please write in english
TakahiroKAMIYA
This "communuty" is Japanese ArcGIS Developer Community supported by Esri Japan.
I expect the Japanese messages Although English messages is not a prohibition.
Esri Japan provides paid "Developer Support". Therefore we cannot give the detailed answer.
However we hope it is better that there is a little more information for other community members.
For example, How do you create GIS Data from DBF Files in your Apprication / How are you adding the data in your Map?
In other, there is also ArcObjectsSDK of community groups that the United States Esri Inc. operated,please alse there to see.
by Anonymous User
Not applicable
OK NP
YusukeInakazu
Avinash-san
Thank you for answering.
Really,I understood that Map was shown!
Map looked as if they are not displayed, but had shifted the location that is displayed.
Not able to search features, it seemed to have failed in its order coordinate calculation.
Sorry over the trouble.
YusukeInakazu
ORUI-san,KAMIYA-san
ご回答有り難うございます。
開発の有償サポートにご連絡させていただく予定です。
不勉強でありGISデータの作成や、Mapのデータ追加の詳細は不明な状態です。
以上、よろしくお願い致します。
