AGOL Java App Login Example (Quartz Beta 2)
1584
08-11-2016 12:40 PM
thomasbales
How do you set an application to login and get secure content from AGOL? There seems to be some documentation and a new Credential class in the beta, but I am not sure how to do this.
Tags (4)
nita14
Occasional Contributor III
Hi Thomas,
here you are:
 Portal portal = new Portal("http://www.arcgis.com");
            UserCredential credentials = new UserCredential("LogiCaseSensitive", "PasswordCaseSensitive");
            portal.setCredential(credentials);
            portal.loadAsync();
            portal.addDoneLoadingListener(new Runnable() {
                @Override
                public void run() {
                    if (portal.getLoadStatus() == LoadStatus.LOADED) {
                        ListenableFuture<PortalUserContent> content = portal.getPortalUser().fetchContentAsync();
                        content.addDoneListener(new Runnable() {
                            @Override
                            public void run() {
                                try {
                                    PortalUserContent myContent = content.get();
                                    for (PortalItem item : myContent.getItems()) {
                                        System.out.println("item title " + item.getTitle());
                                } catch (InterruptedException | ExecutionException ex) {
                                    Logger.getLogger(QuartzBeta2.class.getName()).log(Level.SEVERE, null, ex);
More details on: Access portal content—ArcGIS Runtime SDK for Java (Quartz Beta) | ArcGIS for Developers
Regards,
Adam
nita14
Hi Thomas,
here you are:
            portal.loadAsync();
                @Override
                public void run() {
                            @Override
                            public void run() {
                                try {
Regards,
Adam
thomasbales
I am sorry I was not clear. I am interested in getting content that is assigned to a specific group in my organizational account and therefore I have two options. These are  OAuth 2.0 authentication and app login. The only reference I can find is at Use OAuth 2.0 authentication—ArcGIS Runtime SDK for Java | ArcGIS for Developers ​. But, looking at the Quartz java API reference I can only find a class called Credentials for portal. In it, there is a setCredential from json string something like the code below. I am wondering if this is the way to use the client id and client secret for an app to login to AGOL to get secured content. If it is, I need to know how to format the json string so I can automatically get content. If this is not the way to do it I need some guidance.
I want to create an offline/online app but the content that get delivered to the application has to be secure and from AGOL. Any help is appreciated.
final Portal portal = new Portal("http://www.arcgis.com", true);
portal.setCredential(Credential.fromJson("")); /
Tom
thomasbales
Sorry, just checked my email.
Thank you so much.
thomasbales
Thank you
