MGI m31 to WGS 84 utm 33N which method?
2727
5
08-14-2016 02:53 AM
PatrickSchwager
I want to transform a raster from MGI Austria GK M 31 into WGS 1984 UTM 33N. Which method would fit best?
Thanks in advance,
Patrick
DanPatterson_Retired
unless there is a projected-to-project conversion available within your country, have you ruled out projected-to-GCS-to-projected.   so whatever it takes to get your projected data into a GCS WGS84 coordinate system, then project to your UTM since the datum appears to be the same.
MelitaKennedy
Esri Notable Contributor
Are you looking for which geographic/datum transformation to use to convert from MGI to WGS84? You'll need to use a concatenated transformation. Try MGI_To_ETRS_1989_5 + ETRS_1989_To_WGS_1984.
Note: the first transformation uses the NTv2 file, AT_GIS_GRID.gsb. For some reason, we didn't put in transformation that converts directly from MGI to WGS84 and uses the NTv2 file. I plan to add one in a future release.
Melita
JulieNacos
Hi Melita,
I have a similiar question as I am using Corine's Version 17 (12/2013) Landcover 2006 Vector data - data downloaded in a zipfile from this link here: Corine Land Cover 2006 seamless vector data — European Environment Agency.
Below this text I have enclosed 2 screenshots of the Corine properties: ETRS89/ETRS-LAEA.
What would be the best way to transform and project this data for the most accurate alignment in WGS1984_UTM34N?
Thank you, Julie
MelitaKennedy
Hi Julie,
Either use the Project or Project Raster tool. In the tool for the output coordinate system, you should be able to type in the well-known ID of the UTM zone, 32634, or browse to projected coordinate systems, UTM, WGS 1984 (North). For the geographic transformation, use ETRS_1989_To_WGS_1984.
Melita
JulieNacos
Thank you!
