How to insert data into a grid in modal tab widget
1634
5
08-16-2016 07:39 AM
TylerDunn2
I've got the grid inserted, I just cant figure out how to insert the data. I figure it has something to do with the this.map.addLayers([this.devProjectsLayer]); but no where that I put it makes the data fill the dgrid. I'm guessing it's something simple and I'm just missing it.
define(['dojo/_base/declare',
'jimu/BaseWidget',
'dijit/_WidgetsInTemplateMixin',
'dojo/_base/html',
'dojo/query',
'dojo/_base/array',
'dojo/_base/sniff',
'dijit/layout/TabContainer',
'dijit/layout/ContentPane',
'dgrid/OnDemandGrid',
'dgrid/Selection',
'dojo/store/Memory',
'esri/layers/FeatureLayer',
'esri/symbols/SimpleFillSymbol',
'esri/Color',
'dojo/_base/lang',
'dijit/form/Button'
function(declare,
BaseWidget,
_WidgetsInTemplateMixin,
html,
query,
array,
sniff,
TabContainer,
ContentPane,
Grid,
Selection,
Memory,
FeatureLayer,
SimpleFillSymbol,
Color,
lang
var devProjectsGrid = declare([Grid, Selection]);
var clazz = declare([BaseWidget, _WidgetsInTemplateMixin], {
baseClass: 'jimu-widget-modaltab',
devProjectsLayer: null,
dgrid: null,
postCreate: function() {
this.inherited(arguments);
var columns = [{
label: "Zoom", //wasn't able to inject an HTML <div> with image here
field: "OBJECTID",
formatter: lang.hitch(this, this.makeZoomButton)
label: "Project Name",
field: "NAME"
//restrict sorting to the Project name field
for (var i = 0; i < columns.length; i++) {
if (i == 1) {
columns.sortable = true;
} else {
columns.sortable = false;
this.dgrid = new devProjectsGrid({
bufferRows: Infinity,
columns: columns
}, this.grid);
this.devProjectsLayer = new FeatureLayer("https://gis.cityofthornton.net/arcgis/rest/services/External_Webmaps/DevProjects/MapServer/1 ", {
mode: FeatureLayer.MODE_SELECTION,
outFields: ["OBJECTID", "NAME"]
//define a selection symbol
var highlightSymbol = new SimpleFillSymbol().setColor(new Color([50, 205, 50, 0.25]));
this.devProjectsLayer.setSelectionSymbol(highlightSymbol);
this.devProjectsLayer.on("load", lang.hitch(this, function(evt) {
var query = new Query();
query.where = "1=1";
evt.layer.queryFeatures(query, lang.hitch(this, function(featureSet) {
var items = array.map(featureSet.features, function(feature) {
return feature.attributes;
//idProperty must be set manually if value is something other than 'id'
var memStore = new Memory({
data: items,
idProperty: "OBJECTID"
this.dgrid.set("store", memStore);
//this.dgrid.set("sort", "NAME");
this.dgrid.on(".field-OBJECTID:click", lang.hitch(this, function(e) {
//retrieve the ObjectId when someone clicks on the magnifying glass
if (e.target.alt) {
this.zoomRow(e.target.alt);
startup: function() {
var tc = new TabContainer({style: "height: 100%; width: 100%;"}, this.customContentNode);
//First Tab panel
var theContent = this.dgrid;
var cp1 = new ContentPane({
title: "Ward 1",
content: theContent,
selected: true
tc.addChild(cp1);
//Second Tab Panel
var cp2 = new ContentPane({
title: "Ward 2",
selected: true
tc.addChild(cp2);
//Third Tab Panel
var cp3 = new ContentPane({
title: "Ward 3",
selected: true
tc.addChild(cp3);
//Fourth Tab Panel
var cp4 = new ContentPane({
title: "Ward 4",
selected: true
tc.addChild(cp4);
tc.startup();
zoomRow: function(id) {
this.devProjectsLayer.clearSelection();
query.objectIds = [id];
this.devProjectsLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, lang.hitch(this, function(features) {
//zoom to the selected feature
var devProjectsExtent = features[0].geometry.getExtent().expand(5.0);
this.map.setExtent(devProjectsExtent);
makeZoomButton: function(id) {
//set the feature 'id' as the alt value for the image so that it can be used to query below
var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='" + this.folderUrl + "/images/zoom.png' alt='" + id + "'";
zBtn = zBtn + " width='18' height='18'></div>";
return zBtn;
return clazz;
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi Tyler,
I was able to get this working with the following:
define([
  'jimu/BaseWidget',
  'esri/Color',
  'esri/tasks/query',
  'dojo/on',
  "dgrid/OnDemandGrid",
  "dgrid/Selection",
  "dojo/_base/array",
  'dojo/_base/lang',
  'dijit/form/Button'
  function (
    declare,
    BaseWidget,
    SimpleFillSymbol,
    Color,
    Query,
    on,
    FeatureLayer,
    Grid,
    Selection,
    TabContainer,
    ContentPane,
    array,
    Memory,
    lang
    //To create a widget, you need to derive from BaseWidget.
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
      baseClass: 'jimu-widget-datagrid',
      label: 'Data Grid',
      columns: null,
      //methods to communication with app container:
      postCreate: function () {
        console.log('postCreate');
      startup: function () {
        // Map Feature Layer
        this.devProjectsLayer = new FeatureLayer("https://gis.cityofthornton.net/arcgis/rest/services/External_Webmaps/DevProjects/MapServer/1", {
          opacity: 1,
          outFields: ["*"]
        this.map.addLayer(this.devProjectsLayer);
        // Data Grid
        this.columns = [{
          label: "",
          field: "OBJECTID",
          formatter: this.createZoomButton
          label: "Name",
          field: "NAME"
        // Define selection graphic
                    data: items,
                var projectDataGrid = declare([Grid, Selection]);
                this.grid = new projectDataGrid({
                    minRowsPerPage: "1000",
                    columns: this.columns
                }, this.gridDiv);
                this.grid.startup();
                this.grid.set("store", memStore);
                this.grid.set("sort", "NAME");
                this.grid.on(".field-OBJECTID:click", lang.hitch(this, function(e) {
                    if (e.target.alt) {
        //First Tab panel
            title: "Ward 1",
            selected: true
        tc.addChild(cp1);
        //Second Tab Panel
            title: "Ward 2",
            selected: true
        tc.addChild(cp2);
        //Third Tab Panel
            title: "Ward 3",
            selected: true
        tc.addChild(cp3);
        //Fourth Tab Panel
            title: "Ward 4",
            selected: true
        tc.addChild(cp4);
        tc.startup();
      // Create zoom button
      createZoomButton: function (id) {
        var zoomButton = "<div data-dojo-type='dijit/form/Button'><img src='widgets/DataGrid/images/zoom.png' myAttri='Zoom' alt='" + id + "'";
        zoomButton = zoomButton + " width='18' height='18' title='Zoom to Feature'></div>";
        return zoomButton;
      // Zoom to Selected Feature
I attached the application I was testing with too.
JakeSkinner
Hi Tyler,
define([
  'jimu/BaseWidget',
  'esri/Color',
  'esri/tasks/query',
  'dojo/on',
  "dgrid/Selection",
  "dojo/_base/array",
  'dojo/_base/lang',
  'dijit/form/Button'
  function (
    declare,
    BaseWidget,
    SimpleFillSymbol,
    Color,
    Query,
    on,
    FeatureLayer,
    Grid,
    Selection,
    TabContainer,
    ContentPane,
    array,
    Memory,
    lang
      label: 'Data Grid',
      columns: null,
          opacity: 1,
          outFields: ["*"]
        // Data Grid
        this.columns = [{
          label: "",
          field: "OBJECTID",
          label: "Name",
          field: "NAME"
                    data: items,
                }, this.gridDiv);
                    if (e.target.alt) {
        //First Tab panel
            title: "Ward 1",
            selected: true
        tc.addChild(cp1);
        //Second Tab Panel
            title: "Ward 2",
            selected: true
        tc.addChild(cp2);
        //Third Tab Panel
            title: "Ward 3",
            selected: true
        tc.addChild(cp3);
        //Fourth Tab Panel
            title: "Ward 4",
            selected: true
        tc.addChild(cp4);
        tc.startup();
        return zoomButton;
TylerDunn2
Thanks Jake, worked like a charm!
TylerDunn2
Hey Jake
Curious if you know how to get a different selection to show up when each tab is clicked. I've got queries running to filter out the data, but when I click to change the tab, it doesn't change the data. Example: This is for a current projects map for a city, each tab is a different planner that works for the city. The first query works fine, but when clicking the second tab for the next planner, the data stays the same.
define([
'jimu/BaseWidget',
'esri/Color',
'esri/tasks/query',
'dojo/on',
"dgrid/Selection",
"dojo/_base/array",
'dojo/_base/lang',
'dijit/form/Button'
function (
declare,
BaseWidget,
SimpleFillSymbol,
Color,
Query,
on,
FeatureLayer,
Grid,
Selection,
TabContainer,
ContentPane,
array,
Memory,
lang
label: 'Data Grid',
columns: null,
this.devProjectsLayer = new FeatureLayer("OURSERVER URL", {
opacity: 1,
outFields: ["*"]
// Data Grid
this.columns = [{
label: "Zoom",
field: "OBJECTID",
field: "NAME"
query.where = "PLANNER = 'LH' AND STATUS LIKE 'ACTIVE' OR PLANNER = 'LH' AND STATUS LIKE 'APPROVED' OR PLANNER = 'LH' AND STATUS LIKE 'PROPOSED'";
data: items,
}, this.gridDiv);
if (e.target.alt) {
//First Tab panel
title: "Lori Hight",
selected: true
tc.addChild(cp1);
this.devProjectsLayer2 = new FeatureLayer("OUR SERVER URL", {
opacity: 1,
outFields: ["*"]
this.map.addLayer(this.devProjectsLayer2);
// Data Grid
this.columns2 = [{
label: "Zoom",
field: "OBJECTID",
field: "NAME"
this.devProjectsLayer2.setSelectionSymbol(highlightSymbol);
this.devProjectsLayer2.on("column.label:click", lang.hitch(this, function(evt) { //WHAT TO PUT HERE SO IT LOADS WHEN THE TAB IS CHANGED!!!! WITH JUST "load" IT LOADS ON TOP OF LORI'S TABLE
var query2 = new Query();
query2.where = "PLANNER = 'JR' AND STATUS LIKE 'ACTIVE' OR PLANNER = 'JR' AND STATUS LIKE 'APPROVED' OR PLANNER = 'JR' AND STATUS LIKE 'PROPOSED'";
evt.layer.queryFeatures(query2, lang.hitch(this, function(featureSet) {
var items2 = array.map(featureSet.features, function(feature) {
var memStore2 = new Memory({
data: items2,
var projectDataGrid2 = declare([Grid, Selection]);
this.grid2 = new projectDataGrid2({
columns: this.columns2
}, this.gridDiv);
this.grid2.startup();
this.grid2.set("store", memStore2);
this.grid2.set("sort", "NAME");
this.grid2.on(".field-OBJECTID:click", lang.hitch(this, function(e) {
if (e.target.alt) {
//var tc2 = new TabContainer({style: "height: 100%; width: 100%;"}, this.customContentNode);
//Second Tab Panel
theContent2 = this.dgrid;
title: "Jay Ruchti",
content: theContent2,
selected: true
tc.addChild(cp2);
//Third Tab Panel
theContent3 = this.dgrid;
title: "Ty Robbins",
content: theContent3,
selected: true
tc.addChild(cp3);
//Fourth Tab Panel
theContent4 = this.dgrid;
title: "Nick Nelson",
content: theContent4,
selected: true
tc.addChild(cp4);
tc.startup();
var zoomButton = "<div data-dojo-type='dijit/form/Button'><img src='widgets/Wards/images/zoom.png' myAttri='Zoom' alt='" + id + "'";
return zoomButton;
JakeSkinner
I believe I was creating the grid incorrectly before.  Try the attached widget.
TylerDunn2
Hey Jake
Tired the new grid, and it shows different fields for the second tab (i.e first tab shows project name, second tab shows Global ID) but it's still the same data (OBJECTID<21), just different fields. Any suggestions on getting a totally different batch of data in the second tab (i.e. OBJECTID<50)?
Thanks a bunch for your help
