Can we create, define the LOI layer in WMX?
1083
08-18-2016 07:49 AM
AnthonyBarron
New Contributor III
In Workflow Manager, can we define the LOI layer? Or plan use a web geoform in which customers add a point to a map, add their information, and hit submit. Once submitted, a job is created in WMX, and the associated geometry  is added to the LOI layer with the associated JOB_ID. Will this also give us the ability to zoom to geomtry from inside WMX?
Tags (3)
TopeBello
Occasional Contributor III
Using the  Workflow Manager Server REST API, you can make calls to create jobs. The rest call to create jobs takes a parameter for AOI/POI amongst other things. Take a look at our documentation at this location.
http://workflowsample.esri.com/doc/rest/index.html
Tope
