Schema Locks - Oracle
3796
10
08-22-2016 06:53 AM
RamakrishnaBillakanti
Schema Locks Grayed Out for the Data Owner and Geodatabase Administrator. I'm trying to identify all the locks that exist on a feature class using ArcCatalog. Its an Orancle Database on which I running these operations. I've attached the screenshot for more information. Please let me know what might be causing this strange behaviour on the geodatabase. Thanks.
by Anonymous User
Not applicable
Please make database connection SDE account or Admin account to see locks or kill locks sessions.
Thanks.
Hi Avinash,
I've already used SDE account as well as Data Owner Account to view the locks. It is not showing, Do I need to grant any permissions on the sys tables
by Anonymous User
Not applicable
Hello Rama,
SDE account have permission in SYS DB if not please do that.
SDE account work as master user.
or you can use SDEMON command to view locks
sdemon -o info -I <{users | users_long | config | stats | locks | vars | instances}>
[-q] {[-i {<service> | <port#> | <direct connection>}]
[-s <server_name>] | [-H <sde_directory>]}
[-u <user_name>] [-p <user_password>] [-D <database_name>]
sdemon
Thanks.
Avinash, Do I need to run in command prompt ? Is there any documentation for running this. Thank you for helping me in troubleshooting.
AlexanderBrown5
Occasional Contributor II
Rama,
Be aware that if your ArcSDE is 10.3 or newer, the SDE command line has been deprecated.
For running ArcSDE 10.2 and prior:
ArcSDE Administration Command Reference
Some additional information for ArcSDE:
What's new in ArcGIS for Desktop—Help | ArcGIS for Desktop
Alternatives to using SDE command line tools in ArcGIS | Support Services Blog
~Alex
AsrujitSengupta
Regular Contributor III
To disconnect users from a geodatabase in Oracle, the geodatabase administrator must either be added to the DBA role or granted ALTER SYSTEM and SELECT_CATALOG_ROLE privileges.
Manage connections in Oracle—Help | ArcGIS for Desktop
Try granting these permissions to the SDE schema and then check in Geodatabase Administrator window in ArcCatalog
Hi ASenGupta-esristaff‌ Thank you for your response, Granting those permission on the schema made locks click able (meaning they are no more grayed out). But still I tried editing a layer and looking for the locks using ArcCatalog, It was suppose to show the schema lock but It didn't. Do you think is there anything I need grant permission on. Thank you again for your help.
User35489
Occasional Contributor III
Billakanti,
Mention version for Geodatabase/ArcSDE and Oracle database and ArcGIS Client, please.
Hi Abdullah Environment is on Oracle 12 C, ArcGIS Desktop 10.4 and Geodatabase Version is also 10.4.
