How do you display in table form the information from an imagery layer's raster attribute table?
1159
08-22-2016 09:48 PM
BruceGodfrey
The sample Work with an imagery layer's raster attribute table | ArcGIS API for JavaScript 4.0 shows how to display on the map pixels for specific values.  What code would you add to the sample to show the field names and their attributes as a table to go with the map?
RobertScheitlin__GISP
Bruce,
   Here is some sample code that does that:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Work with an imagery layer's raster attribute table - 4.0</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0/esri/css/main.css">
  <script src="https://js.arcgis.com/4.0/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #sidebar {
      z-index: 99;
      position: absolute;
      top: 0;
      right: 0;
      height: 100%;
      background: rgba(0, 0, 0, 0.5);
      width: 320px;
    #text {
      color: white;
      padding: 3%;
    #raTable {
      font-size: 16px;
      font-family: "Trebuchet MS", Arial, Helvetica, sans-serif;
      border-collapse: collapse;
      border-spacing: 0;
      width: 100%;
      background-color: #fff;
      color: black;
    #raTable caption {
      margin-bottom: 6px;
      color: white;
      font-weight: bolder;
    #raTable table, th, td {
      border: 1px solid white;
    #raTable th {
      padding: 4px;
      background-color: #4CAF50;
      color: white;
    #raTable tr:nth-child(even) {
      background-color: #dffae0;
    #raTable td {
      padding: 4px;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/ImageryLayer",
        "dojo/_base/array",
        "dojo/_base/html",
        "dojo/_base/lang",
        "dojo/domReady!"
      function(
        Map, MapView,
        ImageryLayer,
        arrayUtil,
        html,
        lang
        var rasterAttributes;
         * Create image layer
        var layer = new ImageryLayer({
          url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/NLCDLandCover2001/ImageServer"
         * Add image layer to map
        var map = new Map({
          basemap: "dark-gray",
          layers: [layer]
        view = new MapView({
          container: "viewDiv",
          map: map,
          center: [-112.6, 39.6],
          zoom: 6,
          padding: {
            right: 320 // Same value as the #sidebar width in CSS
        layer.then(function() {
          rasterAttributes = layer.rasterAttributeTable.features;
          var tbl = html.byId("raTable");
          arrayUtil.map(rasterAttributes, lang.hitch(this, function(item, i){
            var row = tbl.insertRow(tbl.rows.length);
            var cell1 = row.insertCell(0);
            var cell2 = row.insertCell(1);
            var cell3 = row.insertCell(2);
            var cell4 = row.insertCell(3);
            cell1.innerHTML = item.attributes.OID;
            cell2.innerHTML = item.attributes.Value;
            cell3.innerHTML = item.attributes.Count;
            cell4.innerHTML = item.attributes.ClassName;
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="sidebar">
      <div id="text">
        <table id="raTable">
          <caption>Raster Attributes</caption>
          <tr>
            <th>OID</th>
            <th>Value</th>
            <th>Count</th>
            <th>Class Name</th>
          </tr>
        </table>
      </div>
    </div>
  </div>
</body>
</html>
Bruce,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #sidebar {
      z-index: 99;
      position: absolute;
      top: 0;
      right: 0;
      height: 100%;
      width: 320px;
    #text {
      color: white;
      padding: 3%;
    #raTable {
      font-size: 16px;
      border-spacing: 0;
      width: 100%;
      color: black;
    #raTable caption {
      margin-bottom: 6px;
      color: white;
    #raTable th {
      padding: 4px;
      color: white;
    #raTable td {
      padding: 4px;
  </style>
  <script>
    require([
        "esri/Map",
        "dojo/_base/array",
        "dojo/_base/html",
        "dojo/_base/lang",
        "dojo/domReady!"
      function(
        Map, MapView,
        ImageryLayer,
        arrayUtil,
        html,
        lang
        var map = new Map({
          layers: [layer]
          map: map,
          zoom: 6,
          padding: {
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="sidebar">
      <div id="text">
          <tr>
            <th>OID</th>
            <th>Value</th>
            <th>Count</th>
            <th>Class Name</th>
          </tr>
        </table>
      </div>
    </div>
  </div>
</body>
</html>
BruceGodfrey
That is very helpful.  Thank you Robert.  -Bruce
Bruce,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
