ArcGIS Portal public maps asking for login credentials
4443
7
08-23-2016 07:46 AM
ClairePeterson
Wondering if anyone could help with this issue that just popped up with our Portal. I have 2 web maps/web mapping applications that are set to be shared with "Everyone" . I copy the link over to a new browser so that I am not logged in to portal and the map begins to load, but after a few seconds the sign in screen appears and asks for a username and password.
We are at a loss as to what would be causing this as we have both "Allow access to the portal through HTTPS only" and "Allow anonymous access to your portal" checked.
JonathanQuinn
Esri Notable Contributor
Taking a look at the web traffic should identify which request is throwing a token error.  Do you have Fiddler installed, or have familiarity with running the Dev Tools within your browser?  If so, take a look at each request as the webmap loads and determine if a specific request returns an error indicating a token is required.  That'll help you pinpoint why the login screen is popping up.
BillDoerflein
Were you able to resolve this.  I am having the exact same issue.
I want to share a map publicly through Portal and not through ArcGIS online.
JonathanQuinn
The network traffic will tell you which item is not shared publicly. When you look at the JSON response, you'll see errors when a request is made for that item. You can then search for that item within the home app to figure out which it is.
GISnIT
Mine is a single feature class?
AdrianMarsden
Occasional Contributor III
 Any solution to this?  I am having the same issue - everything is shared as "everyone" but the embedded code for an Instant App asks for credentials
SumersetEllis
Were you able to find a solution? I'm having the same issue.
AdrianMarsden
somewhere in the chain will be something not shared - I think I found some of the tools weren't.
