Triggering/Listening python in ArcMap
436
08-23-2016 05:10 AM
CharlesLaughton
Hi folks
First time poster, trying to make python do my bidding, most grateful for any assistance. EPSG:27700
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
# oldDFextent = df.extent
# while not df.extent = oldDFextent
elm = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "GridRefField")[0]
elm.text = 'SK' + str(((df.extent.XMax - df.extent.XMin) / 2) + df.extent.XMin)[1:3] + str(((df.extent.YMax - df.extent.YMin) / 2) + df.extent.YMin)[1:3]
arcpy.RefreshActiveView()
del mxd
What i am trying to achieve is a text element on the layout screen which dynamically updates with the dataframe centroid.
However the built-in dynamic text...
<dyn type="dataFrame" name="Layers" property="center" decimalPlaces="0"/>
...doesn't allow me to manipulate the string it returns at all. I am seeking to coerce it into Ordnance Survey map sheet format...
i.e. 462,697.834 390,802.021 becomes SK6290
So, i turn to python. I now have a layout view text element called 'GridRefField', which i am pushing the values i want into using arcpy.mapping. This is working perfectly, but i am having to run the code manually whenever the dataframe extent changes, whereas i want this to just sit in the background and rerun every time the dataframe extent changes a la dynamic text.
How would i go about doing this? Is it doable within python or do i need to move towards coding an AddIn?
Many thanks for any assistance
Charles
JoshuaBixby
MVP Esteemed Contributor
ArcPy doesn't deal with events, at least listening for them, i.e., there is no "triggering/listening" built natively into the site package.  If you want to access ArcObjects events from Python, you can use comtypes or some other Python-based COM interface package.  Even going down that road, I am not sure how, or if, one would get it to work.
